DESCRIZIONE DELL'OGGETTO: Subwoofer dalla indubbie doti soniche. Molto efficente.
Specifications
Nominal Basket Diameter
12" / 300mm
Impedance 8 ohms
RMS Power Rating 150 Watts
Program Power 300 Watts
Frequency Response 25Hz - 4.0kHz
Sensitivity (1W/1m) 93.6dB
Voice Coil Diameter 4" / 100mm
BL Factor 17.2 N/A
Voice Coil Length 12 mm
Air Gap Height 7 mm
X Damage (peak to peak) 28 mm
Magnetic Assembly Weight 14.08 lb. / 6.4 kg.
Mounting Information
Overall Diameter 12.6" / 320mm
Bolt Circle Diameter 11.8" / 300mm
- Front Mount 11.26" / 286mm
- Rear Mount 11.02" / 280mm
No. Of Mounting Holes 8
Volume Displaced By Driver 0.19 ft3 / 5.5 Liters
Overall Depth 4.92" / 125mm
Net Weight 16.3 lb. / 7.4 kg.
Shipping Weight 17.6 lb. / 8 kg.
Materials
Basket Die Cast Aluminum
Cone Paper
Surround
Polyurethane Foam
Voice Coil Edgewound Copper Ribbon
Magnet Ferrite
Thiele-Small Parameters
Resonant Frequency (fs) 29 Hz
Impedance (Re) 6.6 ohms
Coil Inductance (Le) 1.3 mH
Mechanical Q (Qms) 6.49
Electrical Factor(Qes) .31
Total Q (Qts) .30
Comp. Equivelant Vol. (Vas) 5.44 ft3 / 154 Liters
Voice Coil Overhang (Xmax) 3.0 mm
Reference Efficiency 1.2%
Displacement Volume 160 cm3
STATO DELL'OGGETTO: Usato
GARANZIA RESIDUA: Nessuna
CONDIZIONI ESTETICHE: Perfetto al 100%
CONDIZIONI DI FUNZIONAMENTO: Perfetto al 100%
PAGAMENTI ACCETTATI: PostePay, Bonigfico, contanti, paypal (+4%)
SPEDIZIONE/CONSEGNA: A mano entro distanze ragionevoli, paccocelere 3 (a vs carico) €30
PREZZO: €180,00
Le foto a breve
- Indice forum Il Mercatino di Caraudioforum.it Vendo Altoparlanti Subwoofer
- Oggi è 28 apr 2025, 2:44
(Arezzo) - Beyma 12B100R 32cm
- superdok81
Messaggio da superdok81 »
- 3.gif (7.37 KiB) Visto 845 volte
- untitled.png (50.09 KiB) Visto 845 volte
- 2.png (35.82 KiB) Visto 845 volte
