Zed Audio Leviathan III
In realtà della serie III ci sono due versioni, questa è la prima, la seconda serie si differisce per il plexiglass fumè, ed elettronicamente per il banco condensatori un pò più generoso. Ma i dati dichiarati sono gli stessi.
Continuous Output Power into 2 ohm: 330w x 6
Continuous Output Power into 4 ohm: 190w x 6
Continuous Output Power into 6 ohm: 125w x 6
Continuous Output Power into 8 ohm: 100w x 6
Continuous Output Power 3 pairs of channels bridged into 4 ohm: 660w x 3 Channel pairs may be bridged independently
Continuous Output Power 2 channels bridged into 8 ohm: 380w x 3 Channel pairs may be bridged independently
Minimum Speaker Impedance: 2 ohm per channel
Minimum Speaker Impedance in Bridge Mode (2 channels): 4 ohm
Frequency Response at rated power into 4 ohms: 10Hz-30KHz -0.1dB
Input Voltage range for rated power into 4 ohms: 0.25 to 8.6 volt
Input Impedance at 2KHz: 47K ohm
Noise below rated output (30KHz limited) -100dB
Channel separation at 2KHz: >80dB
Damping Factor at 20Hz with 4 ohms: >80
Total Harmonic Distortion with 4 ohm: 0.05%
Protection: Short Circuit, DC, Thermal
Current Consumption with Sinewave at 4 ohms: 94A
Current Consumption with Music at 4 ohms: 18 to 28A
Idling Current: <1.5A
Fuse rating with 4 ohm load: 30A-40A depending on usage
Fuse rating with 2 ohm load: 40A -80A depending on usage
Size W x H (247mmx55mm/9.7”x2.1”) x L: 410mm/16.14” Excludes connectors
Made in USA
Torna a “ZED AUDIO”
