DESCRIZIONE DELL'OGGETTO:
Amplificatore monofonico in classe D specifico per subwoofer 1000W - Macrom M1A.1000D
- 3000 watts IHF Power
- 1000 watts rms into 2 ohms load 14 volts
- 700 watts rms into 4 ohms load 14 volts
- High efficiency Class D design
- Variable 18dB per octave low pass crossover from 30 to 300Hz
- Variable 18dB per octave subsonic filter from 20 to 55Hz
- Adjustable 0 to +15dB at 45hz bass boost
- Pre-amplified output with crossover options
- Muting circuitry for soft turn-on and turn-off
- Frequency response : 20 to 330Hz (+/-0,5dB)
- Sensitivity : 0,2 to 8 volts compatible
- Total Harmonic Distortion : THD < 0,5%
- Signal to noise ratio : > 90dB
- Chrome heatshield
- PWM Mos-Fet power supply
- EBC external bass control
- 20 sq.mm power terminals
- Dimensions : 265 x 50 x 385 mm
STATO DELL'OGGETTO: Usato
GARANZIA RESIDUA: Nessuna
PAGAMENTI ACCETTATI: Ricarica Postepay, Bonifico , paypal (+4%)
SPEDIZIONE/CONSEGNA: a mano / corriere (8€)
Prezzo : € 130
- Indice forum Il Mercatino di Caraudioforum.it Vendo Amplificatori Monofonici
- Oggi è 26 apr 2025, 17:44
[PARMA] Macrom M1A.1000D
- macrom m1a1000d.jpg (15.01 KiB) Visto 2087 volte
