Kenwood eXcelon
ContessaSerbelloni
Kenwood eXcelon
Messaggio da ContessaSerbelloni »
su alcuni siti ameregani ho trovato questi amplificatori
•Kenwood eXcelon XR-4S
•Kenwood eXcelon XR-1S
sui vari forum ne parlano in modo entusiasmante
avete mai avuto occasione di sentirli all opera ????
Re: Kenwood eXcelon
No, mai provati...
ma guardando il budget, credo che siano degli amply entrylevel,
non di certo di alta fascia !
Gli amply Kenwood qua non li teniamo in considerazione! XD ( scherzo )
ma sono in classe D ?!
ContessaSerbelloni
Re: Kenwood eXcelon
The eXcelon Reference Fit amplifiers may fool some, but those who know Kenwood understand the power behind the aluminum plating. These amplifiers have a small footprint allowing installation in even the tightest of locations. For those who need a truly custom installation the top plate can be removed and replaced with a creation of your choice. For such a small size these amplifiers put out a huge amount of power, just don't let it go to waste
•Reference Fit Class D Car Amplifier
•RMS Power Rating:
◦4 ohms: 120 watts x 4 chan.
◦2 ohms: 150 watts x 4 chan.
◦Bridged, 4 ohms: 300 watts x 2 chan.
•Max power output: 300 watts x 4 chan.
•Digital amplifier technology with dual MOSFET switching power supply
•Remote bass level input (Kenwood KAC-X1D remote level control sold separately)
•LED power indicators
•4/3/2 Channel operation
•Line inputs
•AB/A Channel input selector with independent gain adjustment
•Single side exposure of terminals for multi-installation
•3-Way System Protection circuitry (thermal, overload, and speaker short protection)
•Heavy duty aluminum alloy heatsink with built-in cooling fan for extreme heat dissipation
•Removable top plate allows for custom fabricators to easily create their own plates
•Gold-plated RCA level inputs
•Gold-plated screw terminals
•Variable high-pass filter (Low Range: 50-200 Hz, 12 dB/octave | High Range: 2,500-10,000 Hz, 12 dB/octave)
•Variable low-pass filter (Low Range: 50-200 Hz, 12 dB/octave | High Range: 2,500-10,000 Hz, 12 dB/octave)
•Infrasonic Filter (24 dB at 15-40 Hz)
•CEA-2006 compliant amplifier
•Frequency response: 20-20,000 Hz
•Dimensions: 9-1/4"W x 2-1/16"H x 7-9/16"D
•4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
