Toyota Corolla..... 5 anni in breve
oldscool68
Re: Toyota Corolla..... 5 anni in breve
#581
Messaggio da oldscool68 »
desmoraf68 ha scritto:Alessio chiedi a Giulio (kristo) lui ti può aiutare ....complimenti per i nuovi acquisti ...certo che sei proprio fissato per la mela morsata,boia deh! :D
desmo.. non sai nemmeno quanto... pensa che usa questo come shampoo...
shampoo mela.jpg (49.92 KiB) Visto 4026 volte
:D :D :D :D :D :D :D
ridere sempre :D
#582
.... Doveva essere una mela marcia allora..... Mi sono cascati tutti i capelli :no:
desmoraf68
#583
Messaggio da desmoraf68 »
Ahahah
#584
:yush: :yush: :eyefire: :eyefire: :eyefire: T_T T_T
Ecco una bella mail da Ebay:
Premesso che ho acquistato il Carnetix utilizzando la spedizione "guidata" di Ebay con sdoganamento gia pagato.... Ecco qua:
Greetings,
Our Third Party Shipper has recently contacted us in regards to the item ********* that you purchased from your seller. They have informed us that the item did reach the international hub, but your item was damaged due to a package containing leaking disinfectant. Therefore, the item is now lost. I apologize for any inconvenience this has caused you. We wanted to provide you with next steps.
After looking at your transaction I can see that you did not purchase this item on ebay.com, but on another eBay domain. Currently not all eBay domains are covered by eBay buyer protection. However, I can see that you did purchase this item using PayPal, which means that you are still protected.
In order to receive your refund we recommend that you open a case with PayPal to obtain a resolution. Please keep in mind that before you do contact PayPal, we recommend contacting your seller first. Many times the seller is more than happy to make the situation right. If doing this does not yield the desired result, proceed with contacting PayPal for a refund.
To file a dispute on a transaction sent through PayPal:
Log in to your PayPal account.
Click on Resolution Centre near the top of the page.
Click Report a Problem.
Select Item dispute then click Continue.
Click Find transaction ID. A new window displays your transaction history.
Click the Transaction ID you want to dispute.
Click Continue then follow the onscreen instructions.
If you have any other additional questions, please, contact us by phone. To do this simply go to eBay.com and click on the customer support tab at the top right of the screen. Next you will click the contact us button to the right, and need to specify your concern to be routed to the proper department. You will eventually get a pin number and a phone number to call us.
We thank you for all of your eBay business and hope that these steps have been helpful in making your eBay processes more efficient. We truly value you as an important part of the eBay community and wish you the best with your future eBay transactions.
Sincerely,
Emily B.
eBay Customer Service
#585
Di nuovo in cerca... Aspettando il rimborso....... (Molto lontano credo) O_O
#586
Azz....mi spiace Alessio, spero che ti rimborsino, almeno avrai perso solo tempo e pazienza.
Che scalogna. :hmm:
#587
Nel frattempo ne ho trovato un altro.....(sempre dagli USA).
Mancano solo i cavi di collegamento alla batteria e all' accensione, ma si tratta di un semplice connettore molex.... Lo dovrei trovare senza problemi.
Il venditore non lo aveva testato... Quindi ero un po' dubbioso, l'ho preso comunque e prima di spedirlo mi ha mandato la foto sotto..... (Vuol dir poco ma insomma..... :) )
Il macpac power cable kit (kit di collegamento per il mac mini) mi é gia arrivato la scorsa settimana.
Avrò bisogno di una mano per i collegamenti poi.....Giulioooooooooo :hahahah: :hahahah:
Squaletto
#588
Messaggio da Squaletto »
Ciao Alessio,
in Inghilterra lo trovi a prezzi leggermente + alti ma non hai il problema della dogana ed una spedizione + veloce, però sono negozi al di fuori di eBay.
#589
Squaletto ha scritto:Ciao Alessio,
Lo so Gabriele, ma quello che avevo trovato era ancora "inscatolato"... Ho vinto l'asta a 29$ , 31$ di spedizione e 15$ di spese doganali prepagate.....
Totale 76$..... Fai la conversione in € e capisci che non potevo lasciarmelo scappare..... Poi é andata come é andata T_T
Ora vediamo quest'altro..... Qui mi tocca pagare pure la dogana col cVlo che ho :hahahah:
Cosmic
#590
Messaggio da Cosmic »
Alé... come si dice a Parigi... il culo o ce l'hai o te lo fanno... :D
desmoraf68
#591
Alè, dopo Rimini io e Te andiamo a Lourdes. :D
#592
desmoraf68 ha scritto:Alè, dopo Rimini io e Te andiamo a Lourdes. :D
Lourdes? :slow:
Cosa è un raduno hi fi? :hahahah:
Cosmic
#593
Lourdes? :slow:
Devi vedè che roba... certi impianti della Madonna!!!!!!!!!!!!
(scusate... non ho resistito!!! XD XD XD)
#594
Cosmic ha scritto:Devi vedè che roba... certi impianti della Madonna!!!!!!!!!!!!
:hahahah: :hahahah:
#595
Finalmente una buona notizia!!!
Gentile alessio giomi,
Abbiamo esaminato i tuoi reclami ed entrambe le pratiche sono state risolte
a tuo favore.
Abbiamo constatato che il sistema di tracciamento della società di
spedizioni internazionali indica che l'oggetto è stato spedito, ma non è
stato mai consegnato. Poiché la società di spedizioni internazionali e' in
torto, riceverai un rimborso completo per un importo di $75,59 USD.
L'accredito del rimborso sul tuo conto PayPal può richiedere fino a 5
giorni. Una volta completato il rimborso, chiuderemo la pratica.
Grazie per la collaborazione. Per maggiori informazioni sulla pratica,
accedi al tuo conto PayPal e vai al Centro risoluzioni
#596
:yes:
Tutto è bene quel che finisce bene (Supergulp).png (46.09 KiB) Visto 3776 volte
#597
Marsur ha scritto::yes:
:hahahah: :hahahah: dice il saggio:....... :sbusin: bei tempi....
marco80
#598
Messaggio da marco80 »
Dai Ale,come si dice:almeno hai pianto con un occhio solo... ;)
#599
News:
Nuovo alloggiamento per RUX.... Vediamo cosa viene fuori....
#600
Mmmmm.... Mica mi piace sai??? T_T
Credo che toglieró il bordo..... Una volta che l'avrò messo "a filo" glielo ricreo.... Al limite con strisce adesive cromate.... :hmm:
