ESX SXE150.4 vs Gladen RC 105c4 G2
lele3990
Messaggio da lele3990 »
secondo voi, come caratteristiche sulla carta, tra i due per collegare una coppia di midwoofer e un subwoofer
MIDWOOFER 6" 16 CM
Impedenza 4 ohm
Tenuta in potenza 150 watt rms / 300 watt max
frequenza di lavoro 85-6000hz
Sensibilità 99db
Fs 81 Hz
SUBWOOFER 12" (30cm) In cassa reflex
Impedenza 4 ohm
Tenuta in potenza 350 watt rms
qui un video delle prove dell' ESX però la versione SXE250.4 https://www.youtube.com/watch?v=vP6XfGLLDFc
SPECIFICATIONS SXE150.4:
Output Power RMS 4 x 100/150 Watts RMS @ 4/2 Ohms
2 x 300 Watts RMS bridged @ 4 Ohms
Output Power Max. 4 x 200/300 Watts max. @ 4/2 Ohms
2 x 600 Watts max. bridged @ 4 Ohms
Loudspeaker impedance (stereo) 2 – 8 Ohms
Frequency Response 5 – 40 000 Hz (-3 dB)
Total Harmonic Distortion < 0,5 % (1 kHz)
Signal-to-Noise Ratio > 90 dB
Input Sensitivity 0,1 – 7 V
Input Impedance 10 kOhm
Highpass Filter (CH1/2) 10 – 250 Hz @ 12 dB/Octave
Highpass Filter / Bandpass Filter (CH3/4) 10 – 250 Hz @ 12 dB/Octave
Lowpass Filter / Bandpass Filter (CH3/4) 50 – 250 Hz @ 12 dB/Octave
Bass Boost (CH3/4) 0 - 12 dB
Low Level Inputs 4 x RCA (CH 1-4)
High Level Inputs Via enclosed Cable Jack (CH 1-4)
Auto Turn On Only via High Level Inputs
Operating Voltage +12 V (9 – 15 V), negative ground
Fuse Rating 3 x 30 A
SPECIFICATIONS RC105c4:
Channels no 4
Class Type AB
Power @14,4V /1.0% THD
@ 4 ohm stereo: Wrms 4 x 105
@ 2 ohm stereo: Wrms 4 x 150
@ 4 ohm mono: Wrms 2 x 300
Operation supply V 10 -16
Thermal protection °C 80
THD @ 4 Ω / 50% Pmax % 0.25
Signal/noise (1V) dB 99
Band width +- 1 dB Hz 20-20000
Input sensitivity Vrms 0.2-10
Low input impedance Ω 5k
High input impedance Ω 50( with RC-HLT)
Damping @ 1000 Hz 65
Power consumption, idle A 0.96
Power cons. 4 Ω stereo A 45
Weight kg 3,3
Dimensions (over all) l/w/h 357/150/52mm
Dimensions (Heatsink) l/w/h 318/150/52mm
Features:
• Input with low- or high-level signal
• Stable at 2ohm stereo per channel and 4ohm bridge mode
• High-level with autosense function (no remote signal required)
• Variable switchable Low Pass Filter from 45 to 225 Hz or
• Variable switchable High Pass Filter from 45 to 225 Hz
• Optional Level control for CH3/4 (sRTC)
Re: ESX SXE150.4 vs Gladen RC 105c4 G2
Più o meno si equivalgono sulla carta
lorddegio
Messaggio da lorddegio »
Il Gladen lo osservavo tempo fa anche io e mi interessava, proprio per gestire woofer e sub...bisognerebbe provarli
MACROM 54.10 porte post
SUB in arrivo
lele3990
lorddegio ha scritto:Il Gladen lo osservavo tempo fa anche io e mi interessava, proprio per gestire woofer e sub...bisognerebbe provarli
Sul gladen non trovo recensioni, mentre sull'esx c'è un video, che ho postato del modello più potente ma stessa serie, che misura la potenza effettiva che eroga l'amplificatore e rispecchia le caratteristiche che dichiarano con una differenza anche di prezzo di quasi 100 euro in meno del gladen
Inviato dal mio SM-G998B utilizzando Tapatalk
Dai dati dichiarati però il gladen ha un alimentatore migliore, il dato a 2ohm è quasi il raddoppio al contrario dell’esx
Ma comunque bisognerebbe provarli
lele3990
rs250v ha scritto:Dai dati dichiarati però il gladen ha un alimentatore migliore, il dato a 2ohm è quasi il raddoppio al contrario dell’esx
Dalle caratteristiche vedo che l'unico dato che cambia sulla potenza è su i 4 ohm, l' esx è 4x100 watt mentre il gladen è 4x105 watt mentre a 2 ohm e a 4 ohm in mono dichiarano tutti e due la stessa potenza 4x150 watt e 2x300 watt
Più che altro era sapere se vale la pena spendere quasi 100 euro per il gladen
lorddegio
Beh, sarà pure la gamma entry level, ma GLADEN è sempre GLADEN...poi magari suona na ciofeca, questo non lo so.
Così a scatola chiusa proverei il GLADEN.
SUB in arrivo
lele3990 ha scritto: 7 nov 2022, 10:33 Più che altro era sapere se vale la pena spendere quasi 100 euro per il gladen
Si hai ragione, ho letto male
Si equivalgono
Nessuno te lo puo dire dai dati, senza averli provati
