DESCRIZIONE DELL'OGGETTO:
Eamlab El 2.300
Mono, 4 ohms: 1 x 400 Watts @ 13.8V
Mono, 2 ohms: not recommended
190 W AES @ 4ohm per channel
270 W AES @ 2 ohm per channel
100 Watt Rms at 4 Ohm per channel @ 12.8V
180 watt Rms at 2 Ohm per channel @ 12.8V
1 ohm impedance not recomendend
T.H.D. + Noise: 70dB
-THD .03%
-Damping factor >200 @ 4 ohms
-Frequency response 10-25kHz
-SN Ratio >95dB
-Input Gain control
-Low level 200mV- 6V
-Features
Battery Voltage Range of Operation 11V - 14.4V
LED indicator Red is protect, yellow as thermal
-Protection (Short, Thermal, Over current) Yes
-Crossover filter LP Hp
-Variable LP/40hz-320hz/
-Crossover Slope 12dB/ octave
-Dimensions mm
-Length 280mm
-Width 250mm
-Height 55mm
-Quality EAMLAB construction
STATO DELL'OGGETTO:
Usato
CONDIZIONI DELL'OGGETTO:
Ottime
PREZZO: 150,00 euro
METODI DI PAGAMENTO:
Postpay+spese di spedizione a carico dell'acquirente
- Oggi è 25 apr 2024, 13:55
Eamlab El 2.300
