AR GT SQ build Brax/Helix/JBL GTI/HybridAudio/Kimber by LBaudio
Hey Guys! Sorry for language, but since I can not speak Italian, I will post it in English!
Im starting with new personal SQ build in Alfa Romeo GT.
Equipment list:
Source:
- undecided, probably modded Clarion HX or Pioneer ODR as CD transport + digital player or tablet
Front system
Midbas - 2 pairs JBL C660 GTI in ported doorpanel enclosures
Midrange - Hybrid Audio Technologies L4SE (optional JBL 400 GTI)
Tweeter - JBL TC 25 Titanium
Subs:
- 2 x JBL W15 GTI (probably in sealed enclosure due to space limitations)
Processor:
-Helix DSP Pro
Amps:
- Brax X2000 and X2400
-JBL/CROWN BPX2200.1
Cables:
Acessories: Audison fuse blocks, Brax voltmeters, Brax IPC1F + 2 x 2F, Helix Power Station
DLS, Dietz twisted and shielded, QED Silver Anniversary bi-amping, Kimber, Esoteric audio.
Damping
- Silent coat/noise bariere
Equipment list:
Source:
Front system
Subs:
Processor:
-Helix DSP Pro
Amps:
Cables:
Damping
For Fast Moving Concerts
Team LBaudio
Team BRAX
Team Hybrid Audio
Team SCB
Team LBaudio
Team BRAX
Team Hybrid Audio
Team SCB
Re: AR GT SQ build Brax/Helix/JBL GTI/HybridAudio/Kimber by LBaudio
Started with fabrication of A-Pillars that will hold Hybrid Audio L4SE widebander and JBL TC 25 Titanium Tweeter
Pillars cleaned off
Predrilled a bunch of holes for better adhesion between ABS and Fiberglass MDF 4 cm base for baffles test fit with drivers T-nuts installed NEO magnets glued in - they will hold tweeter in place
Pillars cleaned off
- 4EB30DE4-B7A2-4B14-BF39-BD2825BB98E0.jpeg (33.44 KiB) Visto 1431 volte
Team LBaudio
Team BRAX
Team Hybrid Audio
Team SCB
Team LBaudio
Team BRAX
Team Hybrid Audio
Team SCB
Started to work on fiberglass base for pillars - made a mold of the dash/pillar
- 1CC3E5BD-E18F-4B5F-9CBB-DAC5D9702E32.jpeg (44.5 KiB) Visto 1429 volte
- 01BC73CA-658C-42BD-A0A7-AC2937C1119E.jpeg (52.95 KiB) Visto 1429 volte
- C40EEFD5-CDA6-46B1-AA9C-7EFA2C761988.jpeg (53.81 KiB) Visto 1429 volte
- 38597DFD-6105-4AA0-AE8A-8F1129EAABF7.jpeg (36.58 KiB) Visto 1429 volte
- 9C02B5F9-C159-4519-A08E-12C38183B9F5.jpeg (33.4 KiB) Visto 1429 volte
- 17D825F7-3B7B-48A1-82EA-EAD2DA3BD8B5.jpeg (42.89 KiB) Visto 1429 volte
- 73A4AD31-420E-44F9-819D-5A759DEDCF96.jpeg (34.5 KiB) Visto 1429 volte
- CF218B0F-4B2A-4AA6-8747-1504FA1991E2.jpeg (34.94 KiB) Visto 1429 volte
- BBC785A9-71AD-42E0-BC90-957BC5271EF7.jpeg (44.78 KiB) Visto 1429 volte
- 71DB93FA-2851-4FD3-B5C5-19BAB01174FB.jpeg (44.1 KiB) Visto 1429 volte
- 0FEF49F5-BD1E-4898-A44A-3662C98C5CAA.jpeg (39.6 KiB) Visto 1429 volte
Ultima modifica di LBaudio il 15 ott 2020, 15:33, modificato 1 volta in totale.
Team LBaudio
Team BRAX
Team Hybrid Audio
Team SCB
Team LBaudio
Team BRAX
Team Hybrid Audio
Team SCB
Nice Work!!!!
@mark3004 pensaci te a spiegargli che deve ripostare tutte le foto usando il forum
ci provo io.....
please, to post photos in the discussion, use the forum, not external hosts
use this guide:
GUIDE
use this guide:
GUIDE
Thank you for guidance!
Team LBaudio
Team BRAX
Team Hybrid Audio
Team SCB
Team LBaudio
Team BRAX
Team Hybrid Audio
Team SCB
Beatiful work, you got skilled hands!
Those mids are damn sexy!
I'm curious, can you please tell me which tape/sheet you used to cover the dash in order to avoid contamination with the resin (fiberglass)?
Thanks and keep us updated.
MACROM 54.10 porte post
SUB in arrivo
SUB in arrivo
Im using Aluminium self adhesive tape. it is super fine to work with, it conform to shape very easily and it sticks alsp to a slightly greased dash (maxiBrill or similar), it also sticks very good to fabrics and all other sorts of materials. You can get one from TESA. Im buiyng it in BauHaus and similar stores....cost is approx 10-12 EUR for 50cm x 50m. A must have material
You can also use normal kitchen alu foil, but you have to apply a light coat of glue in spray on back side. you can help yourself to apply it tothe surface with brush, just be careful to not tore it appart
Team LBaudio
Team BRAX
Team Hybrid Audio
Team SCB
Team LBaudio
Team BRAX
Team Hybrid Audio
Team SCB
Io non riesco a visualizzare le foto..
Idem non visualizzo
Sono link diretti ad immagini presenti in un altro forum mi sembra di capire.
Datemi una mezzoretta che le scarico e le ricarico tramite forum
@Ink Blue , @Tammaro86 adesso le vedete?
Si ora si vedono
Strano però, io le vedevo sin dall'inizo
Ora le vedo. Grazie Alessio
Anche io.... svelerà l’arcano @Etabeta
Questa era una stringa di una foto:
http://www.audio-kontakt.com/forum/nalo ... 383_2.jpeg
Che poi messa tra [ img ][ /img ] si trasformava in
Edit Etabeta: questa immagine per esempio (ma qui è stata postato proprio come esempio) è linkata con url http (e non https) il che genera, su questa pagina, un avviso di sicurezza nei browser, fateci caso, vicino al "lucchetto" nella barra dell'indirizzo (in Firefox) mentre genera proprio un avviso "Non sicuro" nel browser Edge, e in futuro i browser diventeranno sempre più restrittivi quando viene rilevata una connessione "non sicura".
Motivo per il quale occhio, per chi inserire link esterni (di qualsiasi tipo) specialmente nelle firme, controllare che sia sempre "https" (TUTTI i server web pubblici supportano https a meno che si tratti di server "pizza&fichi" o gettati alle ortiche e non più mantenuti da anni). La presenza di link http inoltre penalizza nel posizionamento sui motori di ricerca.
FINE O.T.
FINE O.T.
Ciao,
nei casi in cui il file di un'immagine (o qualsiasi altro tipo) sia fisicamente in un server esterno a quello del forum c'è modo di sapere a posteriori il perchè, in alcuni casi, non venga scaricato in quanto appunto l'azione di download è tra il browser del singolo utente e il server esterno dove il file risiede.
Premesso ciò, banalmente la causa più comune può essere un eventuale limite di traffico (o numero di richieste contemporanee) posto sul server esterno, oppure si tratta di server che non supportano connessione sicura per cui il browser ne blocca il download automatico, tutti motivi per i quali è fortemente sconsigliato (non voglio usare il termine "vietato"...) utilizzare provider esterni di hosting foto, il risultato è, quasi sempre, di rallentare, a tutti gli utenti che accedono alla pagina, la navigazione oltre al fatto che, praticamente sempre, se viene caricata un'immagine "pesante" questa non viene ridimensionata in anteprima (come avviene invece per le immagini residenti sul forum, quando superano una certa dimensione) e allora l'apertura della medesima, specialmente su connessioni poco performanti, diventa anche moooooolto lenta.
Quindi, nuovamente, la raccomandazione è di usare sempre, sempre, sempre, esclusivamente la funzione di caricamento delle immagini integrato nel forum (con l'eccezione, portiamo pazienza, per chi usa Tapatalk, servizio che usa un suo server per le immagini caricate)
Beatiful, good good work!
I think I saw this install already... DIYMA maybe or Facebook group?
Great job anyway, we're waiting for more pics!
